Mel_B_
Jun 22, 2017Explorer
hbillsmith wrote:
You can add an extended run tank using the Pinellas kit and a standard Yamaha connector outboard marine gas tank. The built in tank is 1.6 gallons good for 4 or 5 hours of A/C. I use a 6 gal. External tank that I share with my outboard. With the external tanks you can swap without worry about spilling gas on a hot genny and causing fire.
Is this what your using?
Extended Run Time Remote Fuel Tank Kit For Champion 3400 Watt Generator Gasoline only Not Dual Fuel
This is not some cheap gravity feed system, it uses an internal fuel pump included in the kit to transfer fuel so the remote tank does not need to be higher than the generator to work.
View Product $249.00
Nice but I don't know about another $250
Mel
