Mel_B_
Jul 09, 2017Explorer
Econ mode is OFF until evening ambient temperature drop
The generator is hot, the compressor is hot, and Econ off let's the generator breathe a little freer, get a little bit more air flow from the engine fan, slightly better cooling for the engine and the electronics
I didn't know this, I ran mine in Econ. in the on position. A/C was running fine, I only ran two hours. One hour on gasoline and an hour on propane. I was under the impression that if it was set in the ECONOMY mode that it would automatpcly speed up to full run capacity if the load demanded it. Am I wrong?
Mel
Mel
