MrWizard
Jul 09, 2017Moderator
Mel
Econ let's the engine slow down when load is low, and saves some fuel
That's why it's called Economy mode
When it's 85 degrees and my A/c is not working to hard and can cool the RV awhile cycling, i will sometimes use Econ mode
But when it's 100 degrees and running full blast to keep up,
Putting heavy load on the generator, flipping Econ off only raises the rpm a little bit, the champ is already running near full bore, l figure why make it struggle to use Econ, let it run , let it have that extra few RPM of engine speed and cooling
You just did a test, and I'm doing an all day run in hot weather
Right now my champ is in Econ mode, but in a few hours maybe at next fill up
I will flip Econ off
Yesterday it was 106f here today forecast in the mid too high 90s
