I need to replace all 4 tires on my TT, a 28BH Grey Wolf. The current wheel size is 14". Would I be better to change over to 15" wheels and tires? I have found a couple places that offer tire and whee...
Going to 15" is a good idea IF you have the space between the tires to accommodate the bigger diameter, so make sure you check to see if 15" Tires/Wheels will even fit. 15" gives you more options in load range, etc.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
