mowermech
Sep 25, 2021Explorer II
obgraham wrote:
In the receptacle on the motorhome there is an "always hot" pin. At least there was on mine. I had them run a separate wire from that pin directly to the toad battery.
THAT is the best idea! Yes, it will require a 7-pin plug on the toad, but that is easily doable. Be sure that "always hot" pin is wired with 10 gauge wire from the power source in the motorhome all the way to the toad battery, and be sure there is a 30 amp fuse or circuit breaker installed in the line at the motorhome power source. Higher amperage may be required.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
