JRscooby
Sep 25, 2021Explorer II
Not sure "always hot" is the best idea. I think a better idea was have the charge pin controlled by the ignition switch of MH. (If it ain't running, it won't charge anyway)
And the toad end can't be mounted solid, unless you use a removable cord. A switch near toad battery to disconnect would stop a hot wire from causing trouble when not towing.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
