dodge_guy
Sep 26, 2021Explorer II
The MH should have a pin that’s 12V hot when the engine is running. I use a 6-way at the toad (standard for RV use). However some cars require the battery to be disconnected to tow. With that you could get a small lawnmower type battery and wire it in as a dedicated battery for he brake controller and run the charge wire to that and run a 12V outlet for the brake system.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
