Russell_Clifton
Apr 02, 2015Explorer
Well,well well. Isn't this interesting. After hearing all you folks saying it should be working, I found this tid-bit on a forum.
F-150 Charging TT battery while towing
This came up when a friend of mine realized that his F-150 was not charging the camper battery while he was traveling. Here's what we found out. Ford does not ship their trucks with the ability to charge a camper battery while towing. Why?? It's our guess that they are concerned with having a 12-V hot wire going the length of the vehicle and it's only being used by those pulling a camper. Here's what they do. All F-150's are shipped with a plastic bag shoved somewhere inside the truck, door or glove box storage. Inside the bag is a fuse, wiring harness with a plug and a relay. The relay goes into slot #9 in the main under hood fuse box just behind the radiator. The fuse, 30-amp goes into slot 21. The wiring harness is used if you don't have the factory installed brake controller.
Sure enough they were in the glove box, and I installed them in the fuse box. Leaving for Alaska April 28th. Thanks for the help!
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
