Tvov
Apr 03, 2015Explorer II
When we first bought our TT, I was using an '87 F350 dually dump truck temporarily. I had the dealer setup the hitch and wiring harness. I just assumed it charged the battery - since the salesman said the TT battery would charge while being towed. When I switched trucks, I found out that the tech at the dealer never bothered to run a charging wire. The trucked I switched to was a used 2000 F250, and it was all setup correctly with the charging wire.
My present 2008 F250 came with everything connected and active.
So, yea, you should double check that your truck is setup for charging.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
