Desert_Captain's avatar
Desert_Captain
Explorer III
Jun 18, 2021
Check in/out timing...
Something to think about...
This summer, like no previous one I can remember virtually every CG/RV Park is booked up well in advance. Most CG's and RV Parks have fairly standard checkin/out times. Typically check in is around 1 or 2 with mandatory check out an hour or two earlier. There are however two different sets of circumstances that folks should consider.
If you are just arriving and checking in to the CG/Park give them a call and usually if your site is empty they will have no problem with you arriving "a little" early. Keep in mind most decent CG/Parks want the opportunity to check and service your site as needed. Some RV Parks will charge about $10 for an early check in and a few will not permit it at all, their park, their rules.
Now as to checking out keep in mind that the check out time is not when you start prepping the rig for departure, that is the time when they need you to be gone, as in down the road.
If you need a later check out it's best to give them as much notice as possible when you "Ask" permission to do so.
We were recently at a busy CG and the staff went out of their way to accommodate as many folks as possible. We had to move twice during our 4 night stay and for us having a 24' Class C this could not have been much simpler. But... if you are moving to another site they HAVE to gone by check out {in this case 1100} so that you can vacate your site on time making room for whoever is moving in behind you. If you are still in my newly assigned site at 1100 someone is probably stacked up waiting for me to be gone and overflow parking if available at all will be at a premium.
On our last day the site we were moving to was open at 1030 and I slid right in. As I was setting up the guy in the site next to us came over and said "you're early". I explained that I had to move in as soon as it opened up so someone else could have mine. I had stayed completely away from the new site so as to not put any pressure on those folks to leave. He was leaving that day but didn't begin his departure routine until after 1100.
IMHO: Once the check out time arrives the site you are in is no longer yours and you need to be gone unless other arrangements have been made.
I spoke with the staff and they confirmed that the folks who are late departing or arrive too early without calling first can cause all sorts of needless headaches. They don't want to be bad guys for anyone and truly appreciate folks who understand and comply with their check in/out times.
So for the sake of discussion I'll ask... Have you ever arrived at your reserved site at the proper check in only to find it fully occupied? How long did you have to wait? Did asking the offending party to move along work or was it necessary to get the staff involved?
As always... Opinions and YMMV
:C
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
