wgander's avatar
wgander
Chevy brake light short
Where do I start looking for a short?
All of the rear lights on my 1997 Chevy Express van work correctly individually. But when the running lights are on and the brake pedal is applied, the bottom right side light bulb goes out. It works OK when the brakes are applied or the lights turned on, but not when both are active at the same time.
The socket is clean and a snug fit. I swapped the left and right light bulbs, and the right one still didn't work correctly.
Do I have to crawl under the van to check the tail light harness?
  • Check out your trailer connector.
    Check out left side tail and brake lights.
    Sounds as though a socket or lamp filaments are short.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
