JBarca
Jun 04, 2013Nomad II
mojoroo wrote:
How easy are they to replace and do you need to reset your WD equipment after an install?
It is extremely likely you will need to reset the WD. Means just about a yes.
If your hitch setup was like mine, I had to buy a new drop shank.
Here is the setup on the original 2003 receiver
Here are the 2 receivers side by side
The newer receiver pin box was higher requiring a lower drop shank to level out the camper. Ended up looking like this
This all depends on the shank you have now and the difference in the new receiver is built in relation to the old one. And then there is the excess twist/flex issues that eats up WD settings.
This is not hard to do, just be prepared for it in the event you get into a height difference.
Hope this helps
John
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
