CapriRacer wrote:
I see this as a multi-level problem:
1) We know that people don't do a good job of checking tire inflation pressures. We can verify that by looking at the results of surveys taken of tires in use.
2) We also know that trailer manufacturers haven't done a good job of supplying tires that have enough rated load carrying capacity. We can verify that by looking at the results of surveys taken of trailer in use - usually done at the same time the tire pressure loads surveys are done.
Side note: Either the trailer manufacturers need to do a better job of estimating the actual loading their trailers experience - OR - they need to do a better job of selecting tires that are rated to carry the loads the tires are being subjected to - or both! (Personally, I vote for both.)
Further, there seems to be a misconception that a) tires are loaded evenly (based on many many comments about weighing the trailer then dividing by 4 to get the tire load) and b) that the tire load tables are recommendations (It says "maximum load" for a given inflation pressure)
3) The tires themselves need to be further developed. I note with interest that most of the large tire manufacturers do not produce ST type tires. The only large manufacturers of note are Goodyear and Cheng Shin (Maxxis).
So I think it is fair to ask about the weight of the trailer (See #1 and #2 above). I see this as less a criticism of the owner and more a step in helping sort out what the cause of the tire failure was - and we know that there is some overloading taking place.
It's also fair to criticize the tire manufacturers.
It's also fair to criticize the trailer manufacturers.
I do not think there is a single answer to the broad question. I'll bet that the reason NHTSA hasn't done anything about ST tires (that we know of) is that they are aware of the loading issues and they are aware that very few trailer tire failures lead to personal injuries - and since "Traffic Safety" is what NHTSA is all about, the lack of personal injury reports doesn't make much of a case for their intervention.
So I say again: If you have a tire failure, report it to NHTSA. They will not act unless there are a large number of reports.
Let me start by saying I have used many ST trailer tires for many years and very many miles and have never had a single roadside tire failure… still using them…
The OE Duro radials that came on my trailer had sidewall bulges on 3 tires in just a few months obviously some high quality Chinese manufacturing went into them…
Another problem I had one time was rubber valve stems going bad and causing leakage… more fine Chinese quality manufacturing…
Still the ST tire I use may not be of the same quality as SOME LT tires… the reason for that is the required standard for DOT certification is not as high for the ST tire as it is for other tires… I am relying on and trusting in the mfg. of my tires to far exceed those minimum standards and built me a quality tire… so far that seems to be what they have done for me and most others that use them…
I truly believe that most of the catastrophic failures we read about are due to operator error or neglect or abuse, or from road hazard… I believe that is true for the ST tire as well as the LT tire, and often is preventable… IMHO tread separation is a major problem for the LT tire to although less than the ST…
However almost all ST tires are mfg. in China where quality can always be questionable at best, and most of those tires are being mfg. without what has been known for many many years to be a critical part in radial tire construction (a full belt cap)… the full belt cap in curing acts like a piece of shrink-wrap over the steel belt, holding it in place and is the greatest aid in preventing separation for the life of the tire, especially at speed… to save cost most ST tire mfg. do not use this cap in their trailer tires, some use just edge strips instead and some may not use anything…
While it has been only recently that some mfg. have started using full caps in some of their tire lines, like the new Carlisle…
The real problem is the standard for DOT certification that sets minimum requirements for the tires safety… those minimum standards are the target that many aim for and all must meet…
If you ask me, if they are going to be sold to use on the highway, the same minimum standard should apply to all tires on those highways…
Nothing prevents a mfg. from exceeding those minimums, but to only pressure they get is from the trailer mfgs. demanding cost containment…
