JoshuaH
Jun 20, 2018Explorer
OK things have changed a little bit. I did a test run with the camper dry with our Jeep and it really struggled to pull it. We have been thinking about getting a larger SUV anyway, and I just found a good deal on a 2007 Toyota 4Runner with the 4.7 V8, so this is going to be our Tow Vehicle.
According to the sticker in the camper the dry weight is 2593 Lbs, however we weighed it at a quarry scale and it weighed 3050 Lbs with nothing in it and the 2 propane tanks removed.
My question is, with this tow vehicle and weight of camper would you suggest I still get a WDH? I at least want sway control even if I don't get a WDH, but I'm certainly not opposed to buying one if it will make things safer, but if I don't need it then I won't do it.
Our loads are going to vary depending on what we are doing, but I can see some trips with a decent amount of weight in the vehicle, for instance on some trips I will have my telescope in the back of the vehicle which weighs about 150 Lbs by itself, along with other luggage and gear.
Thanks!
https://c2.staticflickr.com/2/1785/29048582248_51fc618655_k.jpg
Thanks!
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 09, 2026
