ChiMom
Mar 13, 2014Explorer
There are many PW owners on the Class B forum if you want to view that forum. I have a 2007 and absolutely love the quality of workmanship for the motor coach component. Many new owners have complained about the Ford E350 wandering or "loose" steering, so I suggest you drive it once before buying, even around an empty parking lot. If going out on the highway with the salesman, make sure that the rear tires are inflated to 80 lbs, the front tires to 55 or 60 and the airbags to 60 lbs. The pre-2007 PW Excels need to have rear wheel spacers retrofitted also for better drivability. Sitting on the rear couch while being driven will be quite bouncy given the amount of rear axle overhang. You should also know that Pleasure Way is a company with excellent customer relations. They will help you with info. Good luck!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
