mdcamping
Mar 07, 2013Explorer
Okie1 wrote:
Chlorine in water turns to salt so rinse lawn or shrubs near RV. I think that you need to brush up on your chemistry. And the answer is "NO" to using a strong bleach solution anywhere on your camper. It is way too harsh and actually bleach does not "clean" anything, it bleaches it out. One thing I have found that works extremely well is "Mean Green" from Dollar General, you can use it full strength if needed and won't harm any of the other finishes on your camper.
I DO agree, but I happen to have an exception on that, my first trailer had the white rubber trim that would start to turn black by the end of the summer, my solution was a marine product called Star brite (bleach product), I would spray it on and with a tooth brush would work it in...after a couple of times around the camper my moldings would look factory white...would be careful to rinse :)
Mike
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
