MagillaGorilla
Aug 07, 2017Explorer
John Wayne wrote:
If while hooked up in the campground you are leaving your black and gray tank valves open that is whats causing your problem. The liquid drains off BUT the solids stay and dry out and harden in the tanks. Leave the black tank valve closed until your tank is 1/2 or more full then drain it and flush out the hose when you drain the gray tank.
I most definitely do not leave either valve open. Good question but not my root cause.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
