- jims1ExplorerBribe the neighbors kid to climb up and sweep off the top for you. Just make sure he doesn't fall thru a sky light or vent...
- vanceExplorerI use a California duster on a telescoping pole. Even with the toppers you still get dust and small stuff, like cut grass and etc. I stand on a 6 ft. ladder and dust it off.
- bernirossExplorerI don't do anything. Some stuff comes in with the slide, then goes back out with the slide.
- DtaylorExplorerIf I am being lazy, I use a water hose on one end and wash it off. Not any different than it raining on it. Most of the time I use a broom
- samsontdogExplorerI use a 6 ft ladder to stand on then blow off with leaf blower or if it is early
in the AM I will use a broom - danorenExplorerSoft broom with a telescopic handle.
- AllworthExplorer IIX2 on toppers.
- fj12ryderExplorer IIIOne of the reasons we had slide toppers installed. No need to clean the slide tops. A big plus.
- discovery4usExplorerDrive really fast out of the campground and then bring the slide in just before you hit the highway:E I have an 18 volt ryobi blower that I use. Just have to remeber to charge the battery the night before we leave.
- dahkotaExplorerI climb up onto the roof and sweep. I also use that time to check for leaks, cracks, and other problems. The whole thing, sweeping and checking, takes maybe five minutes. BTW - on our tt at least, the slide roofs aren't rubber.
Looking for advice before your next adventure? Look no further.25,169 PostsLatest Activity: Oct 12, 2025
