Snowman9000
Aug 10, 2014Explorer
There are detectors which use next to nothing. I've checked mine in my current and previous RVs with a multi-meter, and the usage was trivial. Once you find the fuse, you can jump your multi-meter leads across the fuse socket terminals and read the amps being drawn. The circuit might serve more than just the detector, so you'll have to watch for that. My current one draws 0.050a running, with a bit more at startup. So that is 1.2 amps in 24 hours.
If you want to disable it, just find the fuse that it's on, and pull it. Or put a switch in the circuit.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
