JamesBr
Nov 12, 2014Explorer
I would be more concerned if it was going to be below freezing night and cloudy and close to freezing during the day. Otherwise the inside temps should be enough to keep you from freezing up. We have one use left and knowing the cold snap was due I opened the faucets and low points and pulled the water heater annode. I been watching the forecast since and if needed will make a run up to push some pink stuff if I have to. After thanksgiving it will be winterized until we head to FL on Jan 3rd.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
