westend
Nov 06, 2017Explorer
I'd suggest to observe how the crease under the marker light effects the seal of the light to the siding. From the picture, it appears that you may have a gap under the light and that could be a potential leak spot.
Bottom line, anywhere there is an opening into the trailer from the exterior needs to be sealed. The sealing can be a temporary affair until the siding is repaired or replaced.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
