blt2ski
Sep 29, 2018Moderator
Chris,
I'm surprised you lost that much off the front. You do not mention the hitch wt amount.....On my GM's with an 8500 RA spring pack, took 1500 to remove some 300-400 lbs off the FA. With the 600-800 I am assuming you have with the TT you have, maybe 100 lbs off the fa! This is with a crew cab mind you. A shorter WB rig will lose more wt off the FA vs a longer one with the same suspension, assuming same rear overhang......
Marty
Marty
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
