ktmrfs
Oct 03, 2018Explorer III
Padlin wrote:
We carry and use a 15 pint dehumidifier, works perfectly but our trailer is only 140 sq' so you'd need to size one for your trailer. On the down side, they kick off quite a bit of heat, good when it's cool, not so good when it's warm. At times I run the A/C and the dehumidifier at the same time.
Something about running the vent fan with an open window when it's in the 40's just seems a bit off to me so I go this route.
on the heat, a dehumidifier is basically an unvented self contained AC unit. water condenses on the cooling unit, just like a AC unit, drips into the collection pan. but the high side (heat) of the AC isn't outside, it's in the dehumidifier. So, yes they do put out some heat.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
