dodge_guy
Aug 10, 2014Explorer II
Engines/transmissions are the same, gear ratios may be different. A C class is built on a van type chassis, where as a class A is built on more of a truck type chassis. and the A`s will usually have 4.88 gears. all that adds up to a higher GVWR and higher tow rating. I looked at one of the C`s with bunks and the CCC was very low at around 1800lbs! by the time you add all your junk and people you will be way over the GVWR. after all that I would go for a class A. mainly because a class A will have more usable interior room because the captains chairs become part of the living area given both RV`s are the same length.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
