2littletime
Mar 27, 2014Explorer
On my 05 Tahoe, they supplied the short cable that attached to the fuse panel. located in the jack compartment. But in 08 it might be just like my 08 Silverado. Under the steering colum, there is a group of wires that are taped to a bundle of wires. Un-tape these wires. these are for the controller. The P2 or P3 has a short pigtale (wires) that attach to the Tahoe wireing. Also in the controller it gives the instructions on how to hook up.
The 12volt supply to the trailer is not included in this wire harness. There are 2 wires that are loose by the master cylinder that must be connected to the fuse box under the hood. They are also taped loose and the wires have eyelets on them that go to a small and a large post on the fuse box. also must add the fuse. Lift off the fuse box cover and it tells what size fuse to install.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
