- GWolfeExplorer
Ralph Cramden wrote:
path1 wrote:
Towing with bicycle or Prius or what?
Need tow vehicle info in order to help.
??? I posted a picture of the decal installed by the manufacturer of the tow vehicle with the hitch ratings???
I am now trying to find 14K lb spring bars for a Reese round bar hitch I had from a previous rig.
I am also curious as to why I cant tie down my inflatable kayak to the hitch?
If you find 14k bars for your hitch you will go from towing to lifting with that little trailer, lifting is out according to the decal. Sorry you're out of luck. ;) - memtbExplorerProbably “should” consider a tire upgrade on the camper.....N2 is a must!
- kerrlakeRooExplorerYoure fine, that's one of them speshul campers jus for Chevy's.
- Grit_dogTrailblazerUhhh, you're pushing it for sure....
- DutchmenSportExplorerI have a feeling the OP may be teasing us all. But, just in case he's not, .... yes, you can tow that trailer safely ... As stated above, a riding lawn mower will tow it just fine!
FYI, I use to use my riding lawn mower to tow my Pop-up camper around the yard and drive way all the time. Worked wonderful. I still use my John Deere 135 to tow my utility trailer around the yard. The camper in your picture looked bigger than my utility trailer! - path1Explorer
Because a lot of people on RV.net will tell you if it says you can't do it on a label you better not do it! And if you ever get pulled over and a cop sees that label you might go to a big boys time out for 10 to 15 years!
Class 8 truck and dont forget couple extra converter axles and for sure have pilot escort company under contract - goducks10ExplorerI've seen Rickshaws bigger than that. :)
- Tyler0215ExplorerApril fools??????
- Turtle_n_PeepsExplorer
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
