JaxDad
Sep 26, 2017Explorer III
MrWizard wrote:
and that is an "IMPORT" issue between two countries
and not the same thing as the rest of the discussion
i've seen some really beautiful DIY RV's posted in these forums
most of those were Bus conversions
some were sprinter vans or other trucks
some were trailers, including a DIY 5th wheel
according to you, these would not be allowed in a commercial campground until they were inspected and certified as meeting RVIA standard
and just Who is this independent certifying body ?
It is NOT an 'import' issue, the requirement to meet life safety standards applies to ALL RV's regardless of wether they are imported or domestically built, or even homemade units.
As far as the prohibition, it's not just commercial campgrounds, technically, it's occupying the unit period.
As an example, here is the Idaho Life Safety Regulations Brochure.
In it the preamble states "All structures built for use as a dwelling place, including “tiny houses”, must fall into one of the following classifications and are required to comply with the requirements for that classification."
Then further on, in the case of RV's it says "Recreational Vehicles - The Idaho Transportation Department regulates RVs as vehicles for title and licensing purposes through your county vehicle licensing agency. Their width is limited to 81?2 feet and temporary recreational lodging is the only legal use. The placement and occupancy of RVs is regulated by local planning and zoning ordinances.
RVs must comply with American National Standards Institute (ANSI) Standard A119.2 for Recreational Vehicles or ANSI A119.5 Standards for Park Trailers (IC§39-4202). The Recreational Vehicle Industry Association (RVIA) issues an insignia for compliant RVs and Park Trailers."
Just like with electrical safety and the NEC and the building code, life safety standards under the various State and Provincial regulations all refer back national standards.
You can find similar requirements in each jurisdiction.
In many areas the zoning restrictions actually recite the requirement for all vehicles the c/g rents to be compliant.
BTW, the certification is NOT required to be by the RVIA, there are a number of QC and engineering firms that can also certify that there is compliance.
One such firm, Pacific West Associates clearly state in their information what they do, and why they do it. From the above page;
"Currently in the United States, the requirement for a Compliance/Certification label on an RV is recognized in all fifty States and the District of Columbia. Additionally, there are certain States that maintain their own oversight programs and issue a required State-specific Certification Label.
The Certification Label is a statement from the manufacturer or oversight authority that the product is manufactured to the applicable codes and standards. Those standards are the NFPA 1192 2015 Edition, (Recreational Vehicles) the ANSI A119.5 2009 Edition, (Park Models/Tiny Homes), and the National electrical Code Sections 551 and 552 respectively. This certification label can be sourced from any one of several Certified Agencies such as PWA, or an Industry Association. The Industry Association label is administered to their members as a requirement of membership, however, there are many manufacturers that are not members of an Industry Association and as such, they source certification labels from one of the other recognized Certification Agencies."
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
