rexmitchell
Aug 06, 2016Explorer
corvettekent wrote:
Instead of using a water hose just fill your water tank and use it. When you are gone I would be more concerned about the water lines than the tank. Pump some antifreeze in the lines if you think it will stay freezing for a few days or more.
Thanks, will leaving the faucets open avoid the water line issue? I would say it is rare for it to be below freezing for more than a day or so. We usually drop down overnight but by noon the next day are above freezing again.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
