wing_zealot
Aug 07, 2016Explorer
If you are not going to heat it or use antifreeze then you are going to have to blow out the lines. Simply draining won't work, It will leave water In the lines that can freeze and damage the lines or fittings. As small as the lines are it may only take a few hours at below freezing temps for the lines to freeze and cause damage.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
