tiptoptune
Nov 10, 2022Explorer
base rail of 2x3x3/16 rectangle tube in place. A "U" viewed from above, welded sides to ends and torch cut holes to go over 1 inch threaded rod. Welded 17 posts of 1 1/2 diameter by 3 inch tall to base rail at locations where the vertical pipes would be. Pipes go over the the posts and are cross drilled with 5/16 bolts and have a drain hole in. base outside dimension is 12-6 wide and sides are 27 feet long. I initially was going to do 12 wide and am glad i increased to 12-6 wide so can open doors on truck. If had room one of the 14 wide commercially available would be nice. This is in a tight spot so i can still back in and access it.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
