tiptoptune
Nov 10, 2022Explorer
grade in the base rail pic has a swale in it for drainage. Pic posting - i took the plunge and used the hosting url and still could not get past the blocked page with mozilla and norton, used chrome and could.
We pre assembled the roof frame trusses on the ground with the peak fittings and the roof to wall fittings attached and then when I realized how heavy they were i was scratching head how to erect this thing. Few ideas, but in end building a crane that reached about 15 feet worked. Pinned crane to jeep to tow bar brackets with 1/2 inch bolt, chained it back to roll cage to set boom angle, ran winch cable up through pulley at top of crane boome. Tried lifting 3 trusses at once, but could not get height due to truss hitting crane boom so had to do one at a time. we would set truss where it needed to go, position crane over it, raise up, stick tubes in the socket of wall fitting and slipped pipe over the 3 inch stub on base rail. then secured with temp ropes to trees and other to support as built on more. WIfey gave me s#$t that i had to build a crane, but doing off ladder or scaffold would have been a pita. It worked well and i have other project for crane down the road.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
