tiptoptune
Nov 10, 2022Explorer
this one is frame completed. ended up being 13-6 tall using the mid level pitch fittings form ysbw that i think are 110 degrees. I used 2 inch diameter heavy wall 40 galvanized fence posts for the piping. wall thickness is about 1/8 inch. they come in 21 foot so cut in half for 10-6 tall on each side. added collar ties using 1 1/2 galv light weight pipe, and knee braces to give roof more support for snow load using 1 x 1 x 1/8 angle iron, both collar and knee braces attached to 3/16 thick tabs of steel I pre welded to pipes and have 3/8 hole in them for bolting in. Driving in and out is easy, however it is going to be a tight fit height wise when canoes on top, however i plan to excavate a 4-6 inches out in center of gravel to gain clearance. Was just out for 2.5 weeks so now need to complete the awning material. hoping by December we have awning on it but you know how that goes. we already got snow and cold temps here and the short days make for slow progress.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
