cannesdo
Jan 06, 2017Explorer
corvettekent wrote:
The way that I tighten the bearing nut is to tighten the nut with a wrench and turn the wheel, then with the wheel stopped back the nut off and tighten hand tight then install the cotter pin.
I had a loud creaking sound on my trailer too but mine was the leaf spring bushings were bad. I bought a "wet bolt" kit to fix it.
Ah, great idea, makes sense. I'll do that this weekend. The bushings were going to be my next project but it seems suspicious that this started *right* after I did the work on the wheels...right? It will be good to get in there and take a look. Can you tell by looking at the bushings if they're bad? And was it only when you turned?
Thanks so much!
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
