allen8106
Jan 15, 2017Explorer
If you just hand tightened the spindle nut as you say then likely they are not tight enough. Tighten as mentioned by corvettekent above with a wrench. It's also quite possible the bearings and races are now damaged. While you may have the ability to do these things it sounds like you don't necessarily have the experince to or skills to do them. You need to consult an experienced mechanic for this stuff.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
