RambleOnNW wrote:
I recently had a wire fall out of its improperly crimped lug connector in the battery compartment. Thought about repairing it but instead bought new cables online. Lugs are crimped on with a multi-ton press and covered with heat shrink tubing. Quality looks good so far.
WindyNation 4 AWG cables
Takes a bit of care and time but mine look just like this using Harbor Freight crimper IIRC rated 7 ton.
https://www.harborfreight.com/hydraulic-wire-crimping-toolGet my lugs and wire here (they do custom wire crimps too):
https://www.genuinedealz.com/marine-electrical-supply/wire-connectorsIMO solder is best for transistors, small wire and such.
