The_real_wild1
Dec 07, 2016Explorer
lightning driver wrote:The_real_wild1 wrote:
Most rails are universal. Depending on which goose neck hitch you have the Curt my fit just fine. When you assemble is you are supposed towrope the lower into the rails then bolt up everything. If you want I can measure my rails and you can compare them to yours. I have a q20 on mine.
Would appreciate the measurements if you have time.
Center to center is 22" apart on my truck. I installed mine with the quick install brackets for the truck and everything lined up easily for drilling. If you go to the Curt website you might be able to get install instructions with the measurements as well.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
