Houstonkid's avatar
Houstonkid
Curt Q20 w/roller removal?
Hi guys, I am trying to get my hitch out of my truck and having a heck of a time. I am either doing it wrong or not using enough elbow grease.
I am trying to remove the head first to make the unit lighter. I pulled the 2 upper pins and removed the caps over the tube. Is there more to be removed before pulling the head? I was under the impression those 2 pins and the caps were all I needed to get the head off.
Then the base just comes out by pulling the 4 pins from the rail correct?
  • I found it very easy to remove head off Q20 using a flat bar and gently prying up between head and base.
  • Thanks again guys. I got the head out, I didn't know there was a square pin like thing on the head that went down into the base. After wiggling it started slowly coming out.
    I took the head out and then stood over the base and shimmied it to the edge of the tailgate in short lifts. Then summoned my wife and we lowered down into the garage.
  • Houstonkid wrote:
    Thank you guys. I will give it another try. I am hoping my wife can help with the base.
    That base is no joke. My dad has one and it was a job for me and him to put it in/get it out of his Ram...I'd recommend investing in winch overhead at some point.
    Thanks!
    Jeremiah
  • even getting the frame out with the rollers isn't too difficult, it is awkward though--DW & I wrestled ours out last week--now have to get it back in so I can bring the rig to the house to finish getting it ready for winter....
  • Thank you guys. I will give it another try. I am hoping my wife can help with the base.
  • You have it correct. After removing the pins and the 'U' shaped caps the head pulls out. But the rubber damper likes to hold onto the big square shaft so just give a little extra muscle.
    Then remove the four pins holding the base to the bed rails and lift. I personally can't lift it out on my own so I get my son in-law to help. As a side note, my base has 4 little rubber spacers, one under each attachment point, which keeps it more quiet. If yours does as well, be sure you don't loose them. Sometimes they stay attached to the base, and sometime they fall off. I just take them off and keep them with the pins till next season.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
