- lazydaysExplorerSounds like a good deal to me.
- Jeff_GreenoExplorerTo All:
Just so we are all clear on this promotion the product does not have to be in stock to receive the $29 installation rate but it does end December 29th. It is the Express Installation for $79.00 that the product must be in stock for since that installation is to be completed within 48 hours.
Thanks
Jeff Greeno
Service & Collision Dorector Camping World / Good Sam
jgreeno@campingworld.com - dodge_guyExplorer II
monkey44 wrote:
Trick is, IN STOCK ... how many refrigerators do they stock, or any other expensive item.
WH are simple, took me fifteen minutes.
Refrigerators, that would be a deal ...
I've seen some CW's that have fridges, washer/dryers and water heaters in stock. So I hope they're ready. And I'm sure the install is to replace existing items in your RV. Either way I don't think I want CW installing anything for $30 - monkey44Nomad IITrick is, IN STOCK ... how many refrigerators do they stock, or any other expensive item.
Refrigerators, that would be a deal ... - katmann343ExplorerBe sure to read the fine print...
- mileshuffExplorer$29 is a great deal if they do quality work and you can buy the item for a reasonable cost.
Here in AZ we have a car audio chain that has had $1 installs for decades. Problem is that their prices for stereos are well above manufactures list price. Install isn't $1! - I_am_still_waynExplorerI saw a sign in a shop:
You can any two of the three listed
1. Cheap work
2. Fast work
3. Good work
You can have cheap work fast but it will not be good.
You can have good work fast but it will not be cheap.
You can have good work cheap but it will not be fast. - 100tonExplorer
Bumpyroad wrote:
My RV dealer has a sign posted stating, "We fix $5.00 installations". I suppose they also would fix $29 ones.
bumpy
Good one.
This reminds of a sign I see in repair shops from time to time. Goes something like this:
Labor $75.00 per hour
If you watch: $95.00 per hour
If you help: $195.00 per hour
If you tried to repair it before you brought it in $295.00 per hour :S - BumpyroadExplorerMy RV dealer has a sign posted stating, "We fix $5.00 installations". I suppose they also would fix $29 ones.
bumpy
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
