granny_6ExplorerApr 09, 2014Dead batteryWe are towing a 2012 CRV with a Brake Buddy. The battery in the CRV keeps going dead within 90 minutes of towing. Any ideas as to what may be causing this? Very frustrating as we travel!! ...Show More
Gonzo42ExplorerApr 09, 2014Does the Brake Buddy get its power from your toad or from your tug? If from your toad, it will deplete the battery especially if you brake a lot.If from the tug, this should not happen as the charging system keeps the tug's battery charged.You could consider running an extra wire from the tug's charging system to the toad's battery to keep it up to snuff.You don’t need a parachute to skydive, but you do need one to skydive again.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
