rhagfo
Apr 14, 2014Explorer III
MFL wrote:brentbullets wrote:
Well I dewinterized and sanitized water system last week. Saturday was 75 degrees and we got everything all cleaned up and we are ready to go. My better half was against the dewinterizing and I said don't worry it isn't going to get that cold, well it was 22 degrees this morning and expected to be that again Wednesday morning.
What do you think? Frozen pipes?
Unit is a 3 year old Montana 5th wheel, I was told it was rated to 20 degrees. I did leave the furnance on, set to 45 degrees. Am I in for some I told you so's and repair bills?
No one can guarantee that you won't have a problem.
I do think you are OK though. It was a good idea to run the furnace. You should also leave the cupboard doors open where there are water lines, and also the door to the water heater (on the inside of course).
Good luck,
Jerry
I agree if the furnace is on the the inside of the 5er is at 45 should not be an issue. Even over night from a 70 degree day to a 22 degree night should be ok it takes a bit for the water to freeze. How long to make ice in your freezer at -10 degrees?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
