mikeak
May 12, 2016Explorer
Dewinterize/ water problem
I have owned my RV for 6 years and done the winterize / de winterize myself every year but am baffled by my current problem. Hoping someone can help
Model: Winnebago Access 31J (bunk bed model)
I set the valve by the pump to go straight so not towards siphon
I set the drain valve to off
I set the two lines under the sink to be parallel to the lines. Same direction (tried opposite as well
I set the water heater valve in-line
I turn the water pump on and have opened faucets.
Water pours out through drain valve by the back wheel.
Feels like I tried every combination of changing valve directions but nothing is working. All leads to draining water. Water heater is clearly not getting filled up and only tiny bit of water comes out through faucets but a ton is running down the pavement outside....
Any ideas????
Any ideas????
