Homer1
Apr 14, 2014Explorer
I seriously doubt that you have any freeze problems, especially with the heat on.You can find out by using your water tank, pressurize the plumbing system with all valves closed. Pump should quit when pressurized. If it continues to cycle you have a problem. Be sure to by-pass the hot water tank, it most likely would not freeze.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
