twalter
Jul 22, 2014Explorer
Diagonal frame bracing
I just bought a new to me 5th wheel and I've found I have a crack in the frame from the twisting of the axles. I've read the posts about running additional supports across each of the hangers. I've also looks at the Mor Ryde option. It looks like all of these will work by trying applying torque to the hanger if they try to twist. I was considering instead running a diagonal brace between the opposite hangers. Back left to front right and back right to front left. Should eliminate the twist. Has anyone done this. Is there a concern that it would make the frame too rigid? It's a little more work to fabricate because of the angles but I would only need 2 cross members and it should be stronger. I have not seen this done though so I'm looking for expert's advice.
