littlemo's avatar
littlemo
Dicor or Eternabond
I have already searched the forums about caulking but I am still confused about which to use where.
The "Caulking" around my sky light is very thick but it has a crack in the middle almost all the way around.
We are having heavy rains right now and I noticed a small amount of water dripping around one area of the skylight. I got up on the roof and found the crack. I guess when it gets sunny again I will have to replace the caulking on and around everything up there. I just have a tarp up there now.
From reading here it seems silicone is not recommended. What is up there is very wide and very thick. I used Dicor when we put our solar wires through the roof and I have used Eternabond on an older 5th wheel to repair the roof.
Need your expertise!
Thanks
  • I do a twice a year check on all roof jacks and fixtures and all lap sealant.
    The sealant on my '97 5er's skylite pulled up for about 10" on one side in '05. I pulled all that would come off and added Dicor self leveling to that spot.
    I also added a bit of Dicor to a few small hairline cracks in the sealant.
    The unit has never leaked other than hail cracking the same skylite 6 years ago. I replaced it with a unbreakable one made of Lexan.
    I installed the new one as the factory with butyl tape 1st and then Dicor over the edges and screw heads.
    There are other good sealant brand on the market that work just as good as Dicor.
  • Why complicate the issue. Just do like 2oldman suggests but clean the surface first.
    Way I have done it for years
    Because the Dicor is no-longer attached to the roof. It has lifted off the roof. Filling in the cracks now is too late, the damage has been done.
  • OP needs to be sure there's no water left in the skylight frame inside. On mine, there's a rectangular piece of perimeter trim I had to remove and let the wood framing dry out.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
