littlemo's avatar
littlemo
Dicor or Eternabond
I have already searched the forums about caulking but I am still confused about which to use where.
The "Caulking" around my sky light is very thick but it has a crack in the middle almost all the way around.
We are having heavy rains right now and I noticed a small amount of water dripping around one area of the skylight. I got up on the roof and found the crack. I guess when it gets sunny again I will have to replace the caulking on and around everything up there. I just have a tarp up there now.
From reading here it seems silicone is not recommended. What is up there is very wide and very thick. I used Dicor when we put our solar wires through the roof and I have used Eternabond on an older 5th wheel to repair the roof.
Need your expertise!
Thanks
  • My experience has been, for irregular surfaces I use Dicor, for flat surfaces Eternabond.
    I have put new Dicor over existing caulk as long as it's surface was clean. Old Dicor can be removed with "plastic" putty knife if you think it is necessary.
    I have used roof coating and a gallon will cover about 50 Sq. Ft. Once you mix it up, as the one that I used was a two part material, you have only so much time to get work done. Also remainder of gallon will set up and can not be used.
    Also Dicor is about $9.00 a tube and the roof coating $55.00.
  • http://www.surebond.com/SB-140/
    Doesn't react with plastic that skylights are made of. Tube of it came with my new skylight.
    Skylights way over priced IMO. 14" X 22" $124.00
    You can probably find lots cheaper but I got what I could get in a hurry.
    Good idea. Make sure the tarp is covering only the skylight area so you're sure that's where the leak starts.
  • I recommend neither of those for skylight leaks, nor do I think you have to remove any caulk.
    I battled that for years until I found Heng's RV roof coating. Goes on like paint and seals up anything that leaks. Might take a few coats.
  • first off, NO to silicone.
    what you are talking about is what i refer to as putty, it is put around everything up on top.
    what i would do is simply take it off, carefully!, and redo it with a self leveling caulking, any quality caulking will do, when you go to the 'rv' store ask the what they would recommend.
    make sure you don't damage the roofing material.
    if you want to get realllllly facny you can finish it off with the dicor 4 inch tape...
    that will d it.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
