wa8yxm
Mar 10, 2023Explorer III
The proper "Full" level when FULLY CHARGED is 1/4 to 1/8" BELOW the split ring.
Some will tell you it's the bottom of the split ring but if you fill it that full they tend to "Spit" a bit (That Spit means spit out a bit of acid and need more frequent cleaning)...
Why when fully charged? The stuff changes volume as the battery charges... It literally "Fills" the battery If not fully charged go about half way between plate and bottom of filler tube. then charge. and top off.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
