BenK wrote:
Yes...over lap meaning the trailing edge of the plate is behind the leading edge of the trailer tongue bottom
By about 0.50" to 0.75" is my guess
So for the plate to 'get up there' and gouge the trailer tongue, it would have to move forward or the trailer tongue has to move rearward about 0.50" to 0.75"
Ben, thanks for your reply. Just for the record -- nobody has ever said that the plate got up there and gouged the trailer tongue.
That's not how the plate can cause damage to the front of the A-frame.
As the OP said, "
The plate rests under the frame. Or the frame "overlaps" the plate. In other words, the plate cannot ever raise past the bottom of the frame. All the plate can do it rub and put pressure on the bottom of the frame.
The plate can and does exert an upward force on the lowest part of the front of the frame.
From the other photos, it appears that the lowest point is the bottom of the weld bead on the left (drivers) side.
The rear of the plate also can and does move laterally relative to the TT frame due to relative rotation between plate and TT.
This generates a friction force, which can push the bottom of the weld bead laterally, in addition to the upward force on the bead.
There is no need for the plate to "gouge" the frame to do damage.
Regarding "gouging" -- I believe the following photo gives a false impression about a gouge or gouges on the bead and end of the A-frame.
I agree, there does seem to be a major indentation in the weld bead just below the curved portion.
However, if you look at the second photo, I think you will get a very different impression.
Now look at this photo of the same weld bead, taken more recently under different lighting conditions.
The apparent indentation in the previous photo is not there.
However, there does appear to be a slightly-curved weld defect (void) running at an oblique angle at about the same location as the apparent indentation.
Also note that, when in its original position, virtually all of the bead material would have been to the right of the end of the frame.
It would have been impossible for a fork to move the bead to the right without hitting the end of the frame.
And, as far as I can see, there is no evidence of any fork damage on the outside of the end of the frame.
The above photo shows almost complete lack of fusion between bead and base metal.
IMO, it would have been easy for a lateral friction force acting on the bottom end of the bead to separate the bottom portion of the bead from the frame.
At the same time, the upward force on the bead could cause the buckling and cracking at the top of the bead.
That's my interpretation of the photos -- yours might vary.
Ron
