portscanner
Jul 02, 2013Explorer
ScottG wrote:
The "Fail" light only comes on in the event your 12V is low or you run out of propane or it fails to light for any reason. It won't detect a problem with the cooling unit.
It sounds like your cooling unit is blocked so sadly, yes, it's probably time for a new CU or fridge.
Ug!
and I did verify I have 13.4 volts right now and 116.7 VAC so it definately is not a power issue.
I am going to start researching the 12V compressor units.
Unless someone can make a suggestion as to something else to check....???
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
