rk911
Jun 13, 2013Explorer
Dr.Chenny wrote:
It is a ford.
then it's probably not a 454 but a SuperDuty F53 producing 305 hp and you likely have a Class III hitch which is rated at 5000-lbs.
the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR minus the actual weight of the MH as it is loaded for travel (food, fuel, water, LP, clothing, supplies, pets, people and misc. stuff); OR
- the weight rating of the MH hitch (Class II 3500-lbs, Class III 5000-lbs, Class IV 10,000-lbs); OR
- the weight rating of your towbar
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
