mowermech
Jun 13, 2013Explorer II
Just my opinion, NOT a recommendation nor an "OK, go ahead and do it":
Yes, I think you CAN tow it. You won't set any acceleration or speed records, and you may not be able to use overdrive very often, and you will have to inspect your entire hitch assembly often for bends and/or cracks and or loose/stretched bolts, but it can be done.
Would I do it, if it were MY rig? Probably. SHOULD you (or anybody else) do it?
That isn't my decision to make.
Good luck.
Good luck.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
